Auteur Topic: Opvolger K20D deze zomer  (gelezen 41175 keer)
Re:Opvolger K20D deze zomer
« Reactie #240 Gepost op: 15 mei 2009, 14:47:41 »
First report of photographer handling a K-7
As anticipated by Asahiflex here is a report from Mr. Smith (name changed by editor), a photographer handling a real K-7. I believe it is a first of its kind. Mr. Smith prefers to remain anonymous. Mr. Smith has handled a K-7 but may not have been able to actually shoot own images with it, or even to turn it on.
In the words close to those of Mr. Smith:
On a PC, I compared images taken with it to the K10D and the K20D. Better noise performance by far, but it seemed too buttery, like it was heavily processed. I could not tell if the sensor performs better or the processing algorithm is improved that much. I guess a little bit of both.
I saw a video which played back on a PC at 720p and it was a Pentax demo. So, it wasn't actually shot with the K-7 unit I handled. Quality was breathtaking, but again it was a Pentax demo - I expected quality like this. The video was in AVCHD - but it was processed. It was edited with music over it so no sounds of the camera were audible.
I learned that (with current firmware) the camera would not output live video feed through the HDMI port. (Editorial comment: The 5Dmk2 cannot do it either)
It was not that small in my hands (Editorial comment: the hands are a large man's hands which are used to a K10D/K20D). The difference in size is more obvious in pictures than in actual use. It seemed to me heavier than the K20D - although I learned that they're about the same weight.
I learned that it is far more waterproof, like you can drop it entirely in water with no problem.
The material of the K-7 didn't feel like metal to me.
I learned that AF works in video and that it is better than any other AF system Pentax has made so far.
If the video I saw was the real quality of the camera, then it is worth buying for this alone.
Offline Ritro
« Reactie #241 Gepost op: 15 mei 2009, 15:06:26 »
En eindelijk een plaatje van de Mode Dial :)
Heb je ook een id hoeveel cilinders het ding gaat krijgen? Dat, en de handige wyber sensor, heb ik nog nergens kunnen zien.  ;)
Wat een opklopperij zeg!, Als je maar genoeg opklopt valt het resultaat altijd tegen.
« Reactie #242 Gepost op: 15 mei 2009, 15:47:24 »
Jemig, het wordt steeds spannender.
Breathtaking film, dat belooft wat!
Hans
« Reactie #243 Gepost op: 15 mei 2009, 22:31:15 »
Ieder z'n meug. Filmen interesseert me geen ruk. Er zijn ook veel potentiële problemen bekend (slijtage sensor, warmteproblemen, het ontwikkelen van dead/stuck/hot pixels).
Wat betreft dat rapport van die fotograaf: da's dus non informatie. 'Heavily processed' betekent dat hij JPEG heeft geschoten, dus 'better noise performance by far' is onder die omstandigheden niet te controleren. Als ik zoiets zou schrijven, dan zou de hoodfredacteur het in het ronde archief mieteren  ;)
« Reactie #244 Gepost op: 16 mei 2009, 00:13:42 »
Ik ben bang dat we straks inderdaad een nieuw subforum krijgen voor filmpjes  ;)
Dat is er al, het vreemdgangersforum, daarheen wordt je volgens de forumregels verbannen, ook als je met een Pentax camera film schiet.
George
painter
« Reactie #245 Gepost op: 16 mei 2009, 14:12:04 »
;D
Geef toe dat het een wereld van nieuwe mogelijkheden opent. Ik ben bang dat we straks inderdaad een nieuw subforum krijgen voor filmpjes  ;)
Ja ja en straks stoppen ze er ook nog een DS spelletjes computer in, ook maar in een apart subforum.  ;D
« Laatst bewerkt op: 17 mei 2009, 00:40:58 door painter »
« Reactie #246 Gepost op: 16 mei 2009, 18:08:28 »
George
Waarop baseer je dat, George? Het zijn toch foto's, geschoten met een Pentax dSLR?
« Reactie #247 Gepost op: 16 mei 2009, 19:26:07 »
taalgrapje, je kunt helemaal geen film schieten met een dslr, dat kan alleen met een camera waar je een film in stopt.
Kijk maar op het K7 modeknopje, daar zie ik dat je 2 grote filmrollen erop zou moeten zetten, geloof jij dat dat werkt ?
George
Hans
« Reactie #248 Gepost op: 16 mei 2009, 21:41:43 »
George
Ja hoor, met een speciale achterwand.
« Reactie #249 Gepost op: 16 mei 2009, 22:48:36 »
Gheghe.....ghrapjasjes.....
Ik wacht het gewoon lekker af.
Maar ik ben wel ontzettend benieuwd!
