De
Pentax K-01 schijnt binnenkort aangekondigd te worden?
http://www.mirrorlessrumors.com/hot-pentax-k-01-mirrorless-camera-coming-soon/Slechte online vertaling van het Japanse artikel:
Mirror-less machine adopts the name Pentax APS-C sensor K-01?
From readers, courtesy of a mirror-less detailed information about new Pentax equipment.
Pentax new aircraft will be announced by CP +.
The name is K-01
The design of the hands of designers talby au. Rather than the K series, the Optio atmosphere rather reminiscent, like the heavy duty no Ricoh GXR.
K-mount mount. Other DA 40mm F2.8XS, there will be three lens kit with the existing lens.
Black & white body color (black keynote), white and black (white tone), black and yellow (based on black and white, yellow leather) three different colors.
In optical viewfinder, but the presence of EVF, is not clear about internal or external.
The sensor is the same spec K-5. Well as K-5 and the rear LCD.
Full HD video
Second shutter speed to 1 / 4000 of 30 seconds
Contrast AF, AF 81 Split
Built-in pop-up flash
121mm width, 79mm height, 59mm depth
560g in weight with battery
Since reliable information from people, I highly credible. The new machine is so that no optical viewfinder, the mirror-less machine no doubt, the adoption of the mirror-less K mount is amazing value.
59mm depth is certainly partly as a unit of the short flange back mirror-less body is too thick, it may be intact, including the K-mount flange back.
But still wide compared to the Kr-4mm, the height-18mm, so that in-depth and 9mm, I have been a small one around. Seems slightly lighter weight.
Then, I just care whether or not that can be achieved fast contrast AF DA · FA group of current SLR lenses.
Edit door Asahiflex: DA 40mm F2.8XS? XS staat voor "Extra Small"? Ben benieuwd hoe dat nog kleiner kan
