Auteur Topic: Laten we hopen dat de kwaliteit goed is... (DA560mm f/5.6)  (gelezen 14568 keer)
Re: Laten we hopen dat de kwaliteit goed is... (DA560mm f/5.6)
« Reactie #90 Gepost op: 14 september 2012, 10:17:30 »
Het kenmerk van een Petzval is toch dat-ie uit vier elementen bestaat, met een verkitte frontgroep en twee losse achterste elementen? Die configuratie zie ik ook bij de DA560 aan de voorzijde van het diafragma. Dan is het gedeelte achter het diafragma een "field flattener" en tevens de groep die uiteindelijk de AF verzorgt.
Of ben ik nu wederom abuis?
« Reactie #91 Gepost op: 14 september 2012, 14:06:14 »
Ik had ht al eerder gepost, maar wellicht iets meer to the point:
The HD PENTAX-DA 560mm F5.6 ED AW DC extreme telephoto lens has been was initially announced at the CP+ tradeshow in February, 2012 and officially announced in September, 2012 at Photokina. It will go on sale in Q4, 2012.
This lens is designed for the APS-C sensor format. With a modest maximum aperture of 5.6 it promises to be relatively affordable and convenient to carry around.
The lens is optimized for rendering distant subjects particularly sharp and well-defined. The DA 560mm is based on optics used in astronomical telescopes. Contrary to popular belief, the lens is not collapsible (it does feature a built-in retractable hood, however).
The lens is designed for all-weather use (AW) incorporating a total of 29 seals to protect the innards of the lens. It has a built-in filter holder at the rear taking 40.5mm filters. A circular polarizer filter is available which can be rotated without removing the filter from the lens.
The lens has a built-in DC autofocus motor and features Quick-shift which allows the photographer to manually fine tune focus without switching out of autofocus mode.. On cameras with no support for in-lens autofocus motors (*istD series, K100D and K110D) the lens works as a manual focus lens.
This lens features Pentax HD coating, the next generation of multi-coating (supersedes SMC coating).
Optical Construction: 6 elements in 5 groups
Largest Aperture: f/5.6
Smallest Aperture: f/45
Closest Focus: 5.6 m
Max. Magnification: 0.1x
Weight: 3 kg, 6.7 lb
Diam x Length: 130 x 522 mm, 5.1 x 20.5in
Filter Size 40.5 mm rear filter holder, 112 mm front filter threads
Hood: Built-in
Field of View (Diag): 3.0 degrees (APS-C)
Field of View (Hor): 2.5 degrees (APS-C)
Diaphragm: 9 blades, rounded
Autofocus: Built-in motor, No driveshaft
Other features: Quick Shift, Tripod collar
Wat mij wat opvalt, is dat de 560mm is dat alleen de Field of View wordt aangegeven voor APS-C: dus geen hint richting FF. Mij lijkt dat een lens van deze brandpuntsafstand toch al snel geschikt zal zijn voor FF....
Wat mij ook opvalt is een korste scherpstelafstand van 5,6 meter met een vergroting van 1:10. Dat valt mij eigenlijk nogal tegen. Dat had ik liever 1:3 of daar in de buurt gezien! Dat was (naast de optische kwaliteit) toch vooral ook een van de redenen om de Sigma 400mm apo in te wisselen voor de 400mm apo macro.
Belangsrijkste is natuurlijk wel hoe die optisch zal presteren t.o.v. de Sigma's. Ik hou hem in de gaten voor waar ik mijn spaargeld aan moet gaan besteden.....
« Reactie #92 Gepost op: 14 september 2012, 14:18:54 »
Het wachten is op de eerste resultaten, maar ik heb goede hoop dat de 560mm de concurrentie in scherpte overtreft. Overigens hebben oude 500mm+ lenzen vaak ook geen goede kortste instelafstand. Dat ligt blijkbaar aan de aard van het beestje, want die kachelpijpen van toen waren ook allemaal langbrandpunten (minimaal net zo lang als het brandpunt) en geen teles (die korter zijn dan het brandpunt).
Ik weet trouwens niet wat je met een 500mm op een FF moet; ben je vogelaar dan zou ik zeker geen FF gebruiken. En anders heb je op een FF altijd nog de mogelijkheid om te croppen.
« Reactie #93 Gepost op: 14 september 2012, 14:32:59 »
Persoonlijk zit ik helemaal niet te wachten op een FF. Lever ik gelijk weer 1,5x vergroting in. Maar er zijn er genoeg die er kennelijk wel naar smachten en overal zoeken naar hints en het viel mij op dat er geen hint was naar FF bij deze lens. Vandaar mijn opmerking.
« Reactie #94 Gepost op: 14 september 2012, 14:46:53 »
Hangt ook sterk af van de IF groep, als ze die een te kleine diameter hebben gegeven, krijg je al snel vignettering.
Vroeger hadden ze geen IF, dan had je dus een forse schuifbuislengte nodig, en dat is ook weer onhandig (1:1 voor een 500mm betekend 500mm 'extension tube').
Alleen de oudste pentax 500mm en 1000mm waren geen tele, maar sinds halverwege de jaren '60 wel.
« Reactie #95 Gepost op: 14 september 2012, 15:22:32 »
Ik bedoel dat het wat suf zou zijn om een lens als deze zo te construeren dat die alleen geschikt is voor APS-C, zelfs als je alleen maar vaagjes zou denken aan een FF
Mijn Sigma 400mm stelt nog scherp op ongeveer 1,5 meter. En heeft 1:3. Dat vind ik wel mooi en maak ik soms ook zeker gebruik van.
« Reactie #96 Gepost op: 14 september 2012, 16:00:46 »
Maar op 1.5 meter ingesteld, is het brandpunts afstand van de sigma geen 400mm meer, want het is een IF ontwerp.
« Reactie #97 Gepost op: 14 september 2012, 18:19:08 »
Maar een vergroting van 1:3 blijft toch iets heel anders dan 1:10 en dat vind ik zwaarder wegen dan het gegeven dat dichterbij de brandpuntsafstand minder wordt door IF
« Reactie #98 Gepost op: 14 september 2012, 18:27:45 »
Zo krijg je de musjes natuurlijk nog niet beeldvullend in beeld. Misschien kun je er een macroring tussen zetten voor dichterbij werk.
« Reactie #99 Gepost op: 14 september 2012, 18:52:38 »
Precies. Met bijna 24cm over de lange zijde, zit een vogelportretje er niet echt in.
