Auteur Topic: K-3 II rumors  (gelezen 19787 keer)
Re: K-3 II rumors
« Reactie #130 Gepost op: 18 juni 2015, 20:11:20 »
Voor die pixelshift is nog geen externe software, dus voorlopig een gimmick om jpg te maken.
Je hebt toch de ricoh software om die pixelshift raw's aan te kunnen ?
Re: K-3 II rumors
« Reactie #131 Gepost op: 18 juni 2015, 21:08:51 »
Mike Tomkins van Imaging Resource zegt er dit over:
We've heard from some readers asking about raw vs JPEG for the Pixel Shift Resolution feature. Note that you can find DNG raws for every shot we've taken in the gallery, including the high-res mode shots:
http://www.imaging-resource.co...
The images in the Pixel Shift Resolution comparison are out-of-camera JPEGs, with those noted either upsampled or downsampled using Bicubic Smoother / Bicubic Sharper interpolation in Adobe Photoshop, as appropriate.
Note that most software isn't going to recognize that these DNGs contain multiple exposures, just as is the case when shooting in HDR mode. What that means is that if you open a Pixel Shift Resolution DNG raw in, say, Photoshop, Lightroom or DxO Optics Pro, you'll get a usable image but it will in effect only be a single-shot image, with the extra frames completely ignored.
You'll need the latest version of Ricoh's Digital Camera Utility software to handle Pixel Shift Resolution imagery in raw format. Other software would need updates to be able to handle Pixel Shift Resolution raws properly, which would obviously be dependent on the third party modifying their software. So if you're looking at raws, do remember that most likely you're only seeing a single exposure represented!
Offline Thoran
Re: K-3 II rumors
« Reactie #132 Gepost op: 18 juni 2015, 21:41:02 »
Adobe heeft een uitdaging ...  maar pas als Canikon deze tech gaat kopiëren vrees ik.
Re: K-3 II rumors
« Reactie #133 Gepost op: 18 juni 2015, 23:50:46 »
Dan ben je dus niet aan jpg alleen overgelaten .
Re: K-3 II rumors
« Reactie #134 Gepost op: 19 juni 2015, 09:32:36 »
Als ik in een wilde bui een RAW foto maak van 100 MB dan wil ik daar wel mee aan de slag kunnen met software waarmee ik werk. Dat is nu eenvoudigweg nog niet en dus is de functionaliteit van die pixelshift dusdanig beperkt dat ik het een foefje wil noemen. Een niemendalletje.
Re: K-3 II rumors
« Reactie #135 Gepost op: 19 juni 2015, 09:49:23 »
Dan is het ook in voor een wilde bui niet moeilijk om van die RAW met Ricoh software er een 16 bits TIFF van te maken, dan kun je nog steeds met je favoriete software los gaan.
Vergeet niet dat door die pixelshift het raw naar kleuren algorithme niet meer geplaagd wordt door een bayer matrix.
Re: K-3 II rumors
« Reactie #136 Gepost op: 19 juni 2015, 21:03:39 »
Dat is zeker ook nog een mogelijkheid. Misschien moeten ze tiff aanbieden als standaard output voor die functie.
Offline guus
Re: K-3 II rumors
« Reactie #137 Gepost op: 18 juli 2015, 17:59:42 »
er werd hier ergens op het forum een goedkoop adres genoemd voor de K3-II,
maar ik kan het niet meer vinden, ook niet binnen dit topic
these things too
Offline guus
Re: K-3 II rumors
« Reactie #139 Gepost op: 18 juli 2015, 18:58:12 »
dat was 'm ja, TX !
these things too
