Auteur Topic: Nieuwe firmware v.1.02 voor de 645D  (gelezen 919 keer)
« Gepost op: 10 maart 2011, 10:50:14 »
Er zullen hier weinig 645D gebruikers rondwaren, maar toch... :)
http://www.pentax.jp/english/support/digital/645d_s.html
Changes to V1.02:
* When processing Noise Reduction after long exposure, remaining time is displayed on LCD panel
* When mode dial is set to “X”, Flash X-Sync Speed can be set by custom function menu.
* When connecting to a computer via the USB cable, recognized Disk name is changed from [Removable Disk] to [645D].
* If format SD memory card, volume label will be [645D].
* After mirror lock-up, extended standby time (until mirror automatically return to original position) from approximate 1 minute to 5 minutes
* If Auto Power Off setting is shorter than 5 minutes, Auto Power Off setting has priority.
