Auteur Topic: Nieuwe firmware update voor Pentax K3II, K1, K-S2 en K- S1  (gelezen 3437 keer)
Offline Pentax4ever
« Gepost op: 4 augustus 2016, 11:28:23 »
Op het internationale Pentax forum kondigt Pentax nieuwe firmware, versie 1.10 aan voor de Pentax K3II (dus niet voor de K3!). En andere versies voor de K-1, K-S2 en de K-S1
link voor de K3II: http://www.ricoh-imaging.co.jp/english/support/digital/k3_2.html.
Zie onder aan de pagina om de software te downloaden.
Dit o.a. i.v.m. de introductie van de nieuwe 55-300 lens. Verder bevat de update algemene "performance-verbeteringen" die niet nader worden gespecificeerd.
Downloads : Firmware Update
Thank you for using a PENTAX K-3Ⅱ digital camera.
RICOH IMAGING COMPANY, LTD. wishes to announce the release of Firmware Update Software Version 1.10 for PENTAX K-3Ⅱ.
Firmware in this document is the software that runs inside digital cameras.
Changes to V1.10
Corresponded to [KAF4 lens mount] that is equipped with an electromagnetic diaphragm control system.
Enable new lens HD PENTAX-DA 55-300mmF4.5-6.3ED PLM WR RE to shoot stable by updating firmware.
Improved stability for general performance.
Caution
Only PENTAX K-3II users are permitted to download the firmware update.
PENTAX Firmware Update Software for K-3Ⅱ
Name   PENTAX Firmware Update Software for PENTAX K-3Ⅱ
Registered name   k3II_v110.zip (zip type 14,158 Kbytes)
Applied product   PENTAX K3, K-3Ⅱ Silver Edition (de verwijzing hier naar de K3 is onjuist n.m.m.)
To check the version number, press the menu button and select [Firmware Info/Options] in the [Set-up 4] menu then press the four-way controller right.
Updated firmware file   For Mac and windows : zip type
Release date   2016/08/04
Copy right   RICOH IMAGING COMPANY, LTD.
How to check version
[1] Turn ON the camera.
[2] Press MENU button to display MENU screen.
[3] Press the four-way controller right to display [Set-up 4] menu screen.
[4] Select [Firmware Info/Options] in the [Set-up 4] menu then press the four-way controller right.
The firmware version for camera is displayed on the [Firmware Info/Options] screen.
Preparation of update
Blank, formatted SD/SDHC card (32MB or more)
USB cable 3.0 (micro B)
If you are copying the firmware update file to the SD card by connecting the camera directly to your computer.
SD card reader or a computer with a SD card slot.
If you are copying the firmware update file to the SD card using a memory card reader / writer.
Fully charged battery (D-LI90)
*Be sure to use fully charged battery (D-LI90)
If the camera turns off during updating due to lack of battery power, the camera will become inoperable. If this happens, a charge will be made for repairs even if within the warranty period.
Download the updated firmware file
For Windows/Macintosh : k3II_v110.zip 14,158Kbytes, zip type
Updating Procedure
Provide a formatted SD memory card for the update software.
The download file is self-extracting. The following file is extracted.
•Fwdc230b.bin: This is the updated firmware.
Copy the above Firmware file [fwdc230b.bin] to the root directory in the SD card.
If your computer does not have a card slot, you can copy the firmware update file by inserting the SD card into your camera and then connecting the camera directly to your computer.
Insert the D-LI90 battery into the camera and confirm the battery is full by battery level indicator then turn the camera off.
Insert the update SD card (prepared in step 1) into the camera (slot 1) and close card cover.
Turn the camera power on while pressing the MENU button.
"Updates the camera firmware" appears in the LCD monitor.
Ver: 1.00→1.10 will be displayed.
Press the four-way controller to select "Start" and press the "OK" button.
"NOW LOADING" appears on the LCD monitor and updating starts.
Please do not under any circumstances switch off the power before the update is completed.
When update is completed, the "COMPLETE" will be displayed at the left bottom of the LCD monitor, then turn the camera off.
Remove the update SD card from the camera.
*Confirm the version of firmware with above [How to check version].
[Caution]
When updating is finished, the update SD card still contains the Firmware file.
If you want to use this card to take pictures, format the card by the camera to delete firmware file first.
This software may only be used by users who own the PENTAX K-3Ⅱ
This software is covered by a software license agreement. Please read the software license agreement before downloading the software.
You will have agreed with this software license agreement when the download starts.
« Laatst bewerkt op: 4 augustus 2016, 11:34:17 door Pentax4ever »
Offline Jan
    • jongejan.photo
Re: Nieuwe firmware update voor Pentax K3II, K1, K-S2 en K- S1
« Reactie #1 Gepost op: 4 augustus 2016, 11:46:32 »
Dankjewel, geďnstalleerd! Ik bleek nog op 1.00 te zitten...
Offline zwitser
  • Lid
« Reactie #2 Gepost op: 4 augustus 2016, 12:38:11 »
Bedankt.
Gr Ron
2X Sony A7RIII
Offline SanderKikkert
    • Flickr
« Reactie #3 Gepost op: 4 augustus 2016, 14:18:15 »
Thanks !Gr. Sander
Sigma DP1 en DP2 Merrill.
« Reactie #4 Gepost op: 4 augustus 2016, 15:06:04 »
"Corresponded to [KAF4 lens mount] that is equipped with an electromagnetic diaphragm control system.
Improved stability for general performance."
Alleen nuttig als je de nieuwe 55-300 plm zoom hebt. Tenzij je gelooft dat "Improved stability for general performance" echt waar is.
Offline Pentax4ever
« Reactie #5 Gepost op: 4 augustus 2016, 20:26:29 »
Tja...dat is moeilijk aan te tonen natuurlijk als ze er verder geen specificatie bij geven, anderzijds....wat is er op tegen om de laatste software te gebruiken?
Mijn ervaring is dat dit per definitie beter is dan niet updaten.
« Reactie #6 Gepost op: 5 augustus 2016, 00:13:55 »
Het placebo-effect is dan ook een aangetoond fenomeen ;)
Offline Pentax4ever
« Reactie #7 Gepost op: 5 augustus 2016, 11:58:29 »
Voordeel voor jou is in ieder geval dat je berichten over updates die "improved stability" beloven kunt overslaan en daar ook niet op hoeft te reageren. ;D
« Reactie #8 Gepost op: 5 augustus 2016, 12:50:58 »
Ik denk niet dat er voor de K-5 nog updates gaan uitkomen :p
