Auteur Topic: 20 tips voor het gebruik van flits bij fotografie  (gelezen 6172 keer)
Offline vandermark
    • Portfolio Bart van der Mark
« Gepost op: 6 maart 2010, 13:39:06 »
Ik ben sinds kort een beetje fan van Neil van Niekerk en lees regelmatig zijn blog. Op zijn site staat een mooi overzicht van tips voor het gebruiken van flitsen. Mooi uitgangspunt van hem is dat flitsen niet alleen gebruikt wordt om een tekort aan licht aan te vullen maar vooral om de kwaliteit van het licht te vergroten. De 20 tips:
1. don’t fear your flash
It is entirely possible to get amazing results from your flash.  Look at the image above.  It’s done with one on-camera speedlight .. bounced properly. It’s actually pretty easy once you get used to it.  So hang in there ..
2. you need something better than your camera’s built-in flash
You really do need a speedlight that attaches to your camera’s hot-shoe for best results.  You simply can’t get there with just that pop-up flash on your camera.  You need something bigger.  Something that can rotate and swivel.   The manufacturers that try and sell you little add-ons and gizmos and promise you that you will get great results from your pop-up flash after spending a couple of dollars on their crap .. well, they are misleading you.   Get a proper speedlight!
3.  bigger is better
My advice will always be to get the most powerful speedlight you can afford.  The more powerful your speedlight, and the more features it has, the more options you have.
4.  bounce your flash for better results
The larger your light-source, the softer the light.  For that reason we bounce flash.  We’re creating a larger light source.   This implies that when we’re working indoors, and we have walls and a ceiling around us, that shooting with direct flash straight-on is possibly the worst that we can do.  We may as well have stayed with the pop-up flash, and saved ourselves some money.  So, bounce your flash!
5.  use that wall as your softbox!
Don’t be stuck in thinking you can only bounce your flash off the ceiling.  Bounce your flash off the wall(s) behind you, and beside you.  Even try bouncing your flash into the open room behind you.
6.  try for directional light
By bouncing off areas to your side, you can get directional light on your subject, instead of flat lighting.  Here’s another example.
7.  flag your flash
When you bounce your flash to the side, make sure that there is no direct flash spilling on your subject.  I use a piece of cheap black foam, held in place with hairbands, to make sure I only get soft indirect light on my subject.
8.  allow TTL flash to make your life easier
TTL flash technology can allow you to get great results easily, but …
9.  .. nudge your TTL exposure with flash exposure compensation
TTL flash exposure could vary, and it can also give you under or over-exposure.  That’s the penalty for getting good results easily .. your exposure may vary, unless you adjust your flash exposure compensation.  With practice (and a sneak peek at your camera’s preview), you can pre-judge this to a good degree.
10.  TTL flash and manual flash are two very different beasts
You have to understand the difference between TTL flash and manual flash, and how their behaviour differ.  They each have their own benefits.  There are those photographers who disdain TTL flash, and only push one way of using flash – manual flash.  You’ll be a stronger photographer in knowing the differences between manual flash and TTL flash .. and being able to use either with confidence.
11.  understand maximum flash sync speed
It is imperative that you understand what maximum flash sync speed is .. and why it is often a sweet spot when you use flash.
12.  aperture controls flash exposure? … well, maybe
You will often see this short-cut thrown around.  It is true to an extent.  But you need to be aware that aperture affects manual flash exposure, but not TTL flash exposure.  Similarly, you need to be aware that ISO also affects manual flash exposure.
13.  shutter speed controls ambient exposure? .. well, maybe
This is another short-cut which can be misleading since other photographers may well omit in telling you the entire truth … that aperture and ISO also affects ambient light.  Where that shortcut – shutter speed controls ambient light – actually kicks in, is for manual flash, where shutter speed becomes the only independent control for ambient epxosure.  A sublte but important distinction.
14.  gel your flash for tungsten!
If you’re using flash in an environment that is predominantly incandescent lighting / tungsten lighting .. and you want your flash to appear more neutral, and not so blue (or your background so grunge-orange), then gel your flash to join the incandescent spectrum .
15. throw away the tupperware
When working indoors, you can most often get the best results by bouncing your flash.  You don’t need that expensive piece of plastic that is advertised as being the solution to all your flash photography problems.
16.  allow available light in
Sometimes flash is your dominant light source.   Sometimes flash is your only realistic choice.  But it usually looks better if you allow available light to give you some context and colour and mood.
17.  start with the available light, and then add flash
At times it might need a slightly different approach between manual flash, and TTL flash .. but invariably, a good starting point in figuring out what you need to do with your flash, is to start with your ambient light metering and exposure.
18. juggling those three balls – shutter speed, aperture & ISO
In order for you to have a solid starting point for your ambient exposure, and understanding HOW to add flash to that, you absolutely need to know the essentials of your camera – how shutter speed, aperture and ISO inter-relate.  There’s no short-cut.
19.  high-ISO capability is no substitute for good lighting
20.  the end will never be in sight
Learning more about flash photography and lighting is a never-ending journey.
There should always be the aspiration to become better.
That’s the challenge, and that’s also the good news.
DrTalos
Re: 20 tips voor het gebruik van flits bij fotografie
« Reactie #1 Gepost op: 6 maart 2010, 14:34:31 »
Zeker nuttige tips. Met name de laatste ben ik het volkomen mee eens, elk kleine instelling in iso, sluiter, diafragma maar zeker oom de hoek waaronder je flitst en de afstanden tot plafond/muur en afstand tot het object kunnen al grote verschillen in het beeld geven. Er zijn zoveel mogelijkheden bij het maken van 1 bepaald beeld dat je iedere keer weer iets nieuws ontdekt. Blijf dus spelen met je instellingen.
« Reactie #2 Gepost op: 6 maart 2010, 15:11:54 »
Bart, wil je het voor mij vertalen naar het Nederlands?
Offline vandermark
« Reactie #3 Gepost op: 6 maart 2010, 17:09:13 »
Daar heb je Google Translate voor  ;D
Offline PeterN
« Reactie #4 Gepost op: 6 maart 2010, 17:33:01 »
Heb je gepoogd die vertaling te lezen?
Hg, PeterN
Fotograferen is selecteren
Offline vandermark
« Reactie #5 Gepost op: 6 maart 2010, 17:38:31 »
Ja zeker, en het is gebrekkig maar je haalt er wel de info uit die de tips moeten geven.
Offline Fookus
« Reactie #6 Gepost op: 6 maart 2010, 17:51:15 »
perfecte tips!
gr Marcel
Offline Jan V.
« Reactie #7 Gepost op: 6 maart 2010, 18:53:25 »
Ik al een tijdje  :)
Zie 2de linkje in http://www.pentaxian.nl/index.php/topic,7171.msg80764.html#msg80764.
Valt inderdaad heel wat te lezen.
Jan V.
PPG
« Reactie #8 Gepost op: 6 maart 2010, 18:59:59 »
Dit is toch een Nederlandstalig forum?  :P Ik vind het niet prettig als er tekst in een andere taal geplaatst wordt.
florian1200
« Reactie #9 Gepost op: 6 maart 2010, 19:02:00 »
- zucht - okeej Wim, speciaal voor jou:  ::) ;)
1. niet bang voor uw flash
Het is heel goed mogelijk om geweldige resultaten te krijgen van uw flitser. Kijk naar de afbeelding hierboven. Het is gedaan met een on-camera Speedlight .. teruggestuurd naar behoren. Het is eigenlijk vrij gemakkelijk als je eenmaal aan wennen. Dus hangen daar ..
2. moet u iets beter dan uw camera ingebouwde flitser
Je hebt echt een Speedlight dat hecht aan warm van uw camera schoen voor de beste resultaten. Je kan er gewoon niet komen met net dat pop-up flitser op uw camera. Je moet iets groter. Iets dat kan draaien en draaien. De producenten die proberen te verkopen en je kleine add-ons en gizmos en u beloven dat u geweldige resultaten van uw pop-up flitser krijgt nadat ze een paar dollar op hun crap .. goed, ze zijn misleidend je. Ontvang een goede Speedlight!
3. Groter is beter
Mijn advies is altijd om de meest krachtige Speedlight je kunt veroorloven. Hoe krachtiger uw Speedlight, en hoe meer functies het heeft, hoe meer opties je hebt.
4. Stuiteren uw flash voor betere resultaten
Hoe groter uw licht-bron, hoe zachter het licht. Om die reden dat we indirect flitsen. We maken een grotere lichtbron. Dit houdt in dat wanneer we werken binnen, en we hebben een plafond en muren om ons heen, die schieten met directe flits straight-on is misschien het ergste dat we kunnen doen. We kunnen zo goed bleef bij de pop-up flitser en opgeslagen onszelf wat geld. Dus, stuiteren uw flash!
5. Gebruik die muur als je Softbox!
Laat je niet vastzitten in het denken bent kan je enkel stuiteren je flitser uit het plafond. Bounce je flitser uit de muur (s) achter je en naast je. Proberen zelfs stuiteren uw flash in de open ruimte achter je.
6. Proberen voor gericht licht
Door Bouncing Off gebieden aan uw zijde, kunt u gericht licht op je onderwerp, in plaats van platte verlichting. Hier is een ander voorbeeld.
7. Vlag uw flash
Wanneer u uw flash stuiteren naar de kant, zorg ervoor dat er geen directe flits morsen op het onderwerp. Ik gebruik een stuk van goedkope zwarte schuim op zijn plaats gehouden met haarbanden, om ervoor te zorgen dat ik alleen maar zacht indirect licht op mijn onderwerp.
8. Toestaan TTL flitser om u het leven gemakkelijker te maken
TTL Flash-technologie kunt u toestaan om grote resultaten gemakkelijk te krijgen, maar ...
9. .. verschuif je TTL-belichting met flits belichtingscompensatie
DDL flits blootstelling kan variëren, en het kan je ook geven onder of boven-blootstelling. Dat is de straf voor het verkrijgen van goede resultaten gemakkelijk .. uw blootstelling kan variëren, tenzij u uw flitsbelichtingscompensatie te passen. Met wat oefening (en een sneak peek preview op de camera's), kunt u dit vooraf te beoordelen op een goed niveau.
10. TTL flitser en handmatige flits zijn twee heel verschillende beesten
U moet begrijpen het verschil tussen TTL flitser en handmatige flits, en hoe hun gedrag verschillen. Ze hebben elk hun eigen voordelen. Er zijn er fotografen die minachting DDL-flitser, en slechts een manier om druk van het gebruik van flash - handmatige flits. Je een sterkere fotograaf in het kennen van de verschillen tussen de handmatige flits en TTL flitser .. en kunnen gebruiken, hetzij met vertrouwen tegemoet.
11. Begrijpen maximale flitssynchronisatietijd
Het is noodzakelijk dat u begrijpt wat maximale flitssynchronisatietijd is .. en waarom is het vaak een zoete plek wanneer u flash.
12. Diafragma controles flitsbelichting? ... Nou, misschien
Je zult vaak zien deze korte-cut geworpen rond. Het is waar tot op zekere hoogte. Maar je moet ervan bewust zijn dat handmatige diafragma beïnvloedt flitsbelichting, maar niet TTL flitsbelichting. Evenzo, moet je ervan bewust zijn dat ook van invloed op ISO handmatig flitsen blootstelling.
13. Sluitertijd controles ambient blootstelling? .. Nou, misschien
Dit is een ander kort gesneden dat kan misleidend zijn omdat andere fotografen kan heel goed in het weglaten vertel je de volledige waarheid ... dat diafragma en ISO ook van invloed op het omgevingslicht. Wanneer deze snelkoppeling - sluitertijd controles omgevingslicht - daadwerkelijk begint, is voor handmatige flits waar sluitertijd wordt de enige onafhankelijke controle voor ambient epxosure. Een sublte maar belangrijk onderscheid.
14. Gel uw flitser voor wolfraam!
Als u flash in een omgeving die hoofdzakelijk wordt gloeilampen / wolfraam verlichting .. en u wilt dat uw flash meer verschijnen neutraal, en niet zo blauw (of uw achtergrond zodat grunge-oranje), dan is uw flash-gel om de gloeilamp spectrum te treden.
15. Gooi de Tupperware
Bij het werken binnenshuis, dan kunt u meestal de beste resultaten door stuiteren uw flitser. U hoeft niet zo duur stuk plastic dat wordt aangeprezen als de oplossing voor al uw problemen flitsfotografie.
16. Toestaan beschikbare hoeveelheid licht in
Soms flits is uw dominante lichtbron. Soms flits is uw enige realistische keuze. Maar het ziet er meestal beter als u toestaan dat het beschikbare licht te geven u enkele context en kleur en humeur.
17. Starten met het beschikbare licht, en voeg dan flash
Soms kan het nodig hebben een iets andere aanpak tussen handmatige flits, en TTL flash .. maar altijd een goed uitgangspunt voor het uitzoeken wat u moet doen met je flitser, is om te beginnen met je omgevingslicht meet en de belichting.
18. jongleren die drie ballen - sluitertijd, diafragma en ISO
Om voor u een solide uitgangspunt te hebben voor uw ambient belichting, en begrijpen hoe te knipperen toe te voegen aan dat je absoluut nodig om de essentie van uw camera weten - hoe sluitertijd, diafragma en ISO inter-betrekking hebben. Er is geen korte - snijden.
19. Hoge ISO-mogelijkheid is geen vervanging voor een goede verlichting
20. Uiteindelijk zal nooit in zicht
Meer te leren over flitsfotografie en verlichting is een nooit eindigende reis.
Er moet altijd het streven om beter te worden.
Dat is de uitdaging, en dat is ook het goede nieuws.
vertaling Google Translate
